Banco de potencia ( Dyno Race ) Monday 5-3-2007
  • wastegates
    • Dec 2004
    • 351
    • Country: Spain
    Hello friends.
    Monday I go to the Bank of Power (Dyno Race), and asi to know whichever CV and NM with repro of Paul , and opinion interests yours to me on connecting the VagCom.
    When to initiate the test, power to connect my VagCom and to see something interesting?
    That I must do?
    Charles
    Audi S2 Coupe ABY 1994
    Barcelona
    Carlos, are you asking which parts to log on vagcom on your dyno run?
    • wastegates
      • Dec 2004
      • 351
      • Country: Spain
      Hello Greg_S
      My question is:
      To connect VagCom to the car when to make test of power, as I must come?
      And that I can learn?
      Charles
      Barcelona
        Carlos, your best bet is to take a look on S2central.net paul has details and masks on there to use with VAGCOM and details of the output tests etc so you can check the car is in good condition.
        HTH
        • Jas11n
          • 5067
          Carlos, do you mean have vag-com connected to the car while it is on the dyno? If so, yes you can do that and run the "measure blocks" or "vag-scope" to see what the various engine components are doing, TPS, lambda etc.
          The measure blocks and vag-scope readings can then be used in a .xls file (exel) to study later.
          Hope this helps?
          Jas..
          2001 Avus Silver B5 RS4.
          1995 S2 Coupe - sold (sniff)
          • wastegates
            • Dec 2004
            • 351
            • Country: Spain
            Yes yes yes
            As I must come to store those data at the moment for testing?
            Thanks
            Charles
            Barcelona
            • Jas11n
              • 5067
              Connect vag-com to the car when it is on the dyno with the engine running.
              In vag-com, go the "select module" >>> "engine" >>>> "measure blocks",
              Do the power run on the dyno, then click "log".
              The file will be saved in the vag-com folder, or where you tell your PC to save it.
              The file can then be opened in a spreadsheet program like Exel so you can study the information.
              Jas..
              • wastegates
                • Dec 2004
                • 351
                • Country: Spain
                Thanks Jas
                Charles
                Barcelona
                • wastegates
                  • Dec 2004
                  • 351
                  • Country: Spain
                  Not if to come out well.
                  In I complete moment for arising error from communication with ECU .
                  The data that to record the computer:
                  Please, somebody can interpret them with Excel
                  Monday,05,March,2007,10:09:45
                  895 907 551 A ,,2.2l R5 MOTR.RHV HS D02,
                  ,Group A:,'000,,,,,,,,,,Group B:,'001,,,,Group C:,'001
                  ,,,,,,,,,,,,,Engine Speed,Coolant Temp,Lambda Factor,Ignition Timing,,Engine Speed,Coolant Temp,Lambda Factor,Ignition Timing
                  ,TIME,,,,,,,,,,,TIME,Idle 770-830 RPM,70-106 deg C,~ 1.0,Idle 8-12 BTDC,TIME,Idle 770-830 RPM,70-106 deg C,~ 1.0,Idle 8-12 BTDC
                  MARKER,STAMP,,,,,,,,,,,STAMP, /min,°C,, °BTDC,STAMP, /min,°C,, °BTDC
                  ,0.53,209,028,090,113,008,122,048,120,097,039,0.96 ,880,97.3,0.938,8.3,1.37,880,97.3,0.930,8.3
                  ,1.74,209,028,090,113,008,122,048,118,097,039,2.14 ,880,97.3,0.922,8.3,2.56,840,97.3,0.914,8.3
                  ,2.94,209,029,089,113,008,122,048,119,097,039,3.36 ,880,97.3,0.969,8.3,3.77,880,97.3,0.977,9.0
                  ,4.14,209,028,092,113,008,122,048,126,097,039,4.59 ,920,97.3,0.992,6.8,5.02,880,97.3,1.000,7.5
                  ,5.40,209,027,092,113,008,122,048,128,097,039,5.87 ,880,97.3,0.992,8.3,6.28,880,97.3,0.984,8.3
                  ,6.63,209,028,093,113,008,122,048,125,097,039,7.07 ,920,97.3,0.969,6.8,7.48,1040,97.3,0.961,6.8
                  ,7.88,209,029,114,116,008,122,048,120,097,037,8.28 ,1160,97.3,0.922,9.8,8.70,1200,97.3,0.992,11.3
                  ,9.08,209,025,128,119,008,122,048,128,097,034,9.50 ,1320,97.3,1.016,15.0,9.91,1360,97.3,1.023,17.3
                  ,10.27,209,022,143,121,008,122,048,133,097,029,10. 68,1480,97.3,1.031,19.5,11.10,1520,97.3,1.016,21.8
                  ,11.45,209,021,156,122,008,122,048,128,097,025,11. 86,1400,97.3,0.992,18.0,12.26,1440,97.3,1.008,24.8
                  ,12.63,209,021,154,123,008,122,048,130,097,024,13. 03,1560,97.3,1.031,25.5,13.46,1360,97.3,1.000,12.0
                  ,13.83,209,023,137,124,008,122,048,129,097,032,14. 25,1400,97.3,1.016,18.8,14.68,1480,97.3,1.031,21.8
                  ,15.06,209,021,156,125,008,122,048,134,097,024,15. 50,1600,97.3,1.062,25.5,15.91,1400,97.3,1.016,16.5
                  ,16.28,209,018,145,125,008,122,048,130,097,032,16. 70,1160,97.3,1.023,0.8,17.11,880,97.3,1.031,6.8
                  ,17.48,209,026,084,123,008,122,048,133,097,037,17. 91,880,96.6,1.047,9.0,18.33,880,96.6,1.047,8.3
                  ,18.69,207,026,087,121,008,122,048,132,097,038,19. 13,840,95.9,1.031,9.0,19.54,840,95.2,1.023,9.0
                  ,19.91,206,026,086,119,008,122,048,130,097,038,20. 34,840,95.2,1.016,9.0,20.79,840,95.2,1.008,9.0
                  ,21.17,206,026,086,116,008,122,048,128,097,038,21. 59,880,95.2,1.000,8.3,22.07,880,95.2,0.992,8.3
                  ,22.42,206,025,090,113,008,122,048,126,097,038,22. 84,880,95.2,0.984,8.3,23.24,880,95.2,0.977,8.3
                  ,23.64,206,025,090,113,008,122,048,124,097,039,24. 05,880,95.2,0.969,8.3,24.45,880,95.2,0.969,8.3
                  ,24.85,206,025,088,113,008,122,048,124,097,039,25. 27,840,95.2,0.961,8.3,25.68,880,95.2,0.953,8.3
                  ,26.05,206,026,086,113,008,122,048,122,097,038,26. 47,840,95.2,0.953,9.0,26.90,840,95.2,0.945,9.0
                  ,27.32,206,026,086,113,008,122,048,121,097,038,27. 72,840,95.2,0.938,9.0,28.13,840,95.2,0.938,9.0
                  ,28.50,206,026,088,113,008,122,048,125,097,039,28. 93,880,95.2,0.984,8.3,29.33,840,95.2,0.992,9.0
                  ,29.71,206,026,086,113,008,122,048,127,097,038,30. 13,880,95.2,1.000,8.3,30.56,840,95.2,1.016,8.3
                  ,30.95,206,025,088,113,008,122,048,129,097,039,31. 35,880,95.2,1.000,8.3,31.81,880,95.2,1.000,8.3
                  ,32.19,206,034,097,114,008,122,048,127,097,029,32. 61,1440,95.2,0.961,24.8,33.09,1560,95.2,0.945,26.3
                  ,33.46,206,021,160,117,008,122,048,128,097,023,33. 86,1560,95.2,1.008,26.3,34.29,1440,95.2,1.023,25.5
                  ,34.66,206,028,121,119,008,122,048,130,097,026,35. 07,920,95.2,1.000,19.5,35.49,600,95.2,0.977,18.0
                  ,35.87,206,071,037,136,008,122,048,121,097,032,36. 29,480,95.2,1.000,15.0,36.69,640,95.2,0.984,16.5
                  ,37.07,206,045,081,144,008,122,048,122,097,027,37. 50,920,95.2,0.930,22.5,37.90,1000,95.2,0.906,22.5
                  ,38.26,205,038,111,141,008,122,048,112,097,026,38. 66,1120,94.5,0.875,22.5,39.08,1200,95.2,0.930,23.3
                  ,39.46,205,033,125,138,008,122,048,124,097,025,39. 86,1280,94.5,1.000,24.8,40.29,1320,94.5,1.039,25.5
                  ,40.64,205,037,140,136,008,122,048,130,097,023,41. 05,1440,94.5,0.969,27.8,41.49,1520,94.5,0.930,29.3
                  ,41.84,205,034,157,134,008,122,048,113,097,020,42. 29,1600,95.2,0.844,30.8,42.70,1640,95.2,0.860,31.5
                  ,43.09,206,033,169,133,008,122,048,118,097,019,43. 52,1720,95.2,0.977,32.3,43.93,1760,95.2,1.039,32.3
                  ,44.30,206,033,182,132,008,122,048,132,097,017,44. 72,1840,95.2,0.977,33.8,45.12,1880,95.2,0.922,34.5
                  ,45.49,206,034,194,131,008,122,048,111,097,017,45. 90,1960,95.2,0.899,35.3,46.32,2000,95.2,0.961,35.3
                  ,46.70,206,033,205,130,008,122,048,131,097,016,47. 12,2080,95.2,1.086,35.3,47.55,2120,95.2,1.094,35.3
                  ,47.92,206,032,216,130,008,122,048,131,097,016,48. 35,2200,95.2,0.961,35.3,48.75,2200,95.2,0.891,34.5
                  ,49.13,206,032,223,129,008,122,048,121,097,017,49. 55,2240,95.2,1.008,34.5,50.00,2240,95.2,1.078,34.5
                  ,50.36,206,032,230,129,008,122,048,143,097,016,50. 80,2320,95.2,1.047,35.3,51.21,2360,95.2,0.969,35.3
                  ,51.56,206,032,240,129,008,122,048,116,097,016,51. 98,2400,95.2,0.938,35.3,52.43,2400,95.2,1.016,35.3
                  ,52.78,206,033,246,129,008,122,048,139,097,016,53. 21,2480,95.2,1.117,35.3,53.61,2520,95.2,1.039,35.3
                  ,53.98,206,033,255,129,008,122,048,123,097,016,54. 39,2560,95.2,0.883,35.3,54.81,2600,95.2,0.961,36.0
                  ,55.18,206,033,255,128,008,122,048,133,097,016,55. 58,2640,95.2,1.109,36.0,55.99,2640,95.2,1.070,36.8
                  ,56.38,206,010,223,128,008,122,048,128,097,029,56. 81,1760,95.2,1.000,6.0,57.26,1240,95.2,1.000,9.8
                  ,57.64,206,022,088,130,008,122,048,128,097,035,58. 07,920,95.2,1.008,6.0,58.51,1000,95.2,1.039,7.5
                  ,58.87,206,083,106,131,008,122,048,128,097,037,59. 29,1080,95.2,1.000,9.8,59.69,1120,95.9,1.000,11.3
                  ,60.06,208,091,122,131,008,122,048,128,097,034,60. 47,1280,96.6,1.000,14.3,60.89,1320,97.3,1.000,15.8
                  ,61.26,209,090,141,130,008,122,048,128,097,030,61. 66,1480,97.3,1.000,18.8,62.09,1560,96.6,1.000,20.3
                  Charles
                  Barcelona
                    wastegates, if they are in a csv file open excel and click import and then select csv file and it will do the rest
                    • wastegates
                      • Dec 2004
                      • 351
                      • Country: Spain
                      Ok Greg_s
                      Charles
                      Barcelona
                      • wastegates
                        • Dec 2004
                        • 351
                        • Country: Spain
                        Ahhhhhhhh
                        284 cv & 410,6 Nm
                        Charles
                        Barcelona
                        • Jas11n
                          • 5067
                          • wastegates
                            • Dec 2004
                            • 351
                            • Country: Spain
                            Graphics
                            Charles
                            Barcelona
