When i let go of the gas pedal it seems like they gauges loose power a bit ... it flickers also ... the maxxecu show about 13,4--3,45 volt charging ,, the generator is all refurbished and checked. But the thing is when give it a bit acceleration then it wakes up but still not good ,, it flickers. Is there something with some kind of ground issue ? The temperature for the water shows about 105C. It not correct it was 85C on maxxecu. So something is giving the gauges strange current. Is there somekind of common ground for the 3 gauges ? Watertemp uses i guess ground from the engine and its a single wire ??
The three guages act strange.... look at the video
Tags: None -
New info , this is multiple movies i think 5 short ones , filmed one after another. At the end when i rev the engine the fan raditor fan stops working .. when it comes down to idle the fan starts again, And the gauges shows different from timer to time. And the water says between 90 and 120 but i know its correct .. about 87 ..
Heres the link
