Hi Folks,
how thick washer do you use on the engine mounts to keep the clearance between the hood and the engine on the Coupe chassis? Around 4mm? I have Verkline (red) engine mounts and AAT diesel block. Not sure how thick it has to be to have clearance between.
Thanks
Tom
Thanks
Tom
I will make these washers 5mm thick and will see. Hopefully, it will clear the space. Won't this washer affect the level of the gearbox and prop shaft?
