What ECU to use on UR S4 @ 400+bhp?
  • K7ERG
    • 1711
    Is it possible to get a remap which will allow for different turbo Gt3071R or Gt3076R with tubular manifold, cams, exhaust change (No cats) front mont intercooler, injectors etc.
    Or will i have to look at aftermarket management (Autronic)
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    you
    still use your ecu, but you need a chip, a new setup for the new turbine and injectors etc. If you are aming at 400hp you will need to do something to the engine too.. the original pistons etc can take 380max
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
    • K7ERG
      • 1711
      Thanks for the reply at least thats a saving and less hassle.
      380bhp on stock pistons
      What about the rest of the internals?
      Injector size?
      Craig
      07947385043
        Personally I think you need to take time out and speak directly to Corey or MRC via PM or the phone as you have posted alot of questions that are quite basic in terms of tuning and have been covered on the forum in numerous posts.
        The AAN engine is the same as the ABY basically so all the tuning options of the S2 apply to the S4
        They can point you in the right direction for your money and spec you wish to acheive and you can plan a proper road map for your upgrade.
        What your doing is getting advice from one person then going back to another person who gave you different advice and challenging it.
        Whilst this can be good it's also counter productive as there are tuners out there that don't believe the bhp figures and tuning methods often practiced on this forum are possible using a standard ECU or equipment.
        • K7ERG
          • 1711
          Ok i will do mate. Just new to tuning Audis and trying to find my feet.
          Craig
          07947385043
          • S4turbo
            • Nov 2005
            • 81
            • Country: Norway
            Original pistons are good for lots of horses (600 +), rods are the first weakness. Yeah, talk to mrc or similar, they will guide you down the slippery slope!
            J
              Craig
              I understand but your at a vunerable stage where cheque book tuners would head hunt you as a customer telling you you need xyz for 10k when you need xy and can do it for £2.5k for example.
              A good chat with Corey for example getting the basic spec right is essential IMO also it will help you with your understanding.
              Also try searching the forum and reading on key words such as remap, pistons, RS2 turbo etc
              There's one for example by Newsh 3b to RS2 spec and one by Ross Project 400 which show an engine being rebuilt up to suitable spec.
              There's another older thread by Doug_RS2 of MRC tuning less applicable now but you can see the type of things people have gone through to get to a certain power level.
              • K7ERG
                • 1711
                Checked out the Project 400 by Ross
                07947385043
