Hi all, I need to replace the lambda sensor on my ABY coupe. Does anyone have any guides/tips for doing that? How much time should I put aside for it? Thanks!
How-to/guide for lambda sensor replacement?
It's very easy. You need the proper socket with cut away side for the wire or run a ring spanner down the wire. Follow the wire to the connector and unplug making a note of where its clipped to the body. I would spray with good penetration oil a day before you start. The new sensor should come with aluminium paste on the threads to help prevent it seizing. It's a bit tight in there and I normally remove the airbox for better access. Don't over tighten or you could strip the threads.Nothelle S2 Avant
