I have an S2 (Avant) which is being refettled, but I also have a 1989 Jetta Syncro with a 1.8T. Trouble is it's in Ireland and was done recently in England, and true to sods law it developed this problem once back in Ireland.
It will boost to 0.6 bar and then if the revs are increased past say 3/4K it will move up slowly to 1.0 bar of boost. When this unknown problem is not holding it back from boosting, it boosts up to 1.5 bar immediately once it goes past say 3K. Rolling road said 362 @ 6150 and 472 @ 4800.
It has a new IHI turbo, steel rods, s3 pistons, running remapped original loom and ECU etc..
I've replaced the boost solenoid valve and the blue 4 pin temperature sensor, but have not yet discovered the problem. Obviously the loss of almost 1 bar of boost detracts from the enjoyment of driving the car.
I know I should get the ECU read for fault codes but the dealers are too busy with long leasd times and I'm not convinced they would be interesrted or care.
I will probably blag a vag-com read, reset, and reread from Mark over here as soon as he can oblige, I still have to ask him, but in the meantime if the cure to the problem is standing out a mile to anyone, needless to say I'd be greatful for their tuppence worth?
The principles should be the same as the S2 with less complication if anything, well less sensors anyway.
Thanks!
Thanks!
