Anyone used EFI Motorsport for a replacement G40 Hall sensor?
  • CoupeWannabeS2
    • 403
    Hi all,
    So I am looking for a new hall sensor for my S2 ABY which won't start and is throwing the fault code 00515.
    I have found EFI Motorsport sell these as per the link below, I note that I have to reuse the original sensor bracket which sounds straight forward enough.
    Anyone have any experience of buying this sensor from EFI Motorsport they could share, or are any other suppliers I should consider?
    *Update: now with longer wires! Our new batch of sensors can be wired to a new 3 pin male connector without splicing in new wires! 500mm overall wire lead length* The camshaft position sensor (G40 in the factory manuals) is located behind the cam gear and reads the 'shutter wheel', sending a hall effect pulse to the EC
  • vag_noob
    • Nov 2010
    • 72
    • Country: New Zealand
    HKZ-101, try your local electronics store but the listed price is ok if you didn't have to ship internationally.
    • johne
      • Apr 2007
      • 1404
      https://www.aliexpress.com/item/3221...Cquery_from%3A
      or: https://www.aliexpress.com/item/1005...Cquery_from%3A
      I've got a bag of 10 of them somewhere if you get desperate.
      • CoupeWannabeS2
        • 403
        Thanks guys, I will give those options a look.
