Help - cranking but not starting!
  • curlyks2
    • 1069
    Help please - what could cause this? After a faultless 180 miles (120 + 15 + 15 + 15 + 15) over two days, my ABY S2 failed to start in the morning for the return journey. Battery is fine - it cranks over but doesn't start - the fuel pump doesn't run and there's no spark/ignition. All thoughts welcome!
    Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
  • sal_s2
    • 1288
    The cam sensor can fail all of a sudden. Try pouring some hot water down the front of engine between the cambelt cover and cam cover. Sometimes that can work
    • curlyks2
      • 1069
      Thanks Sal. Hot and cold have made no difference, but blink codes say 2113 - G40 camshaft position sensor - so looks like the right place (and wiring) to be looking.
      • bluequattro
        • 2960
        Doesn't cam sensor always show a fail when the engine isn't running?
        My bet would be on an ECU fuse failure
        • sal_s2
          • 1288
          Its the crank sensor that shows a fault when not running
          • curlyks2
            • 1069
            It lives! Replaced the camshaft position sensor and it then started first turn of the key.
            • K Simmonds
              • Dec 2007
              • 7627
              Back of the net!!
              1990 B3 2.0 80 quattro.
              1992 C4 2.8 Avant quattro
              1994 MTM RS2.
              1998 B5 TDI quattro Sport.
              2000 B5 TQS.
