Does anyone know if there is an equivalent Bosch part for the Turbo Coolant Pump (034-965-561C).
I think I've discovered my coolant leak source, but have a severely scalded arm as a result... Hrmm.. I should have read this warning on SJM's site prior...
"CAUTION: The Turbo secondary electric water pump has plastic fittings which can break off while working under the hood if you bump into the pump fittings and this can spray HOT BOILING COOLANT on you causing severe burns. I have had the "pleasure" of experiencing this and have the burn scars to prove it. WEAR SAFETY GOGGLES and PROTECTIVE CLOTHING while working around a hot engine! The radiator fittings are also plastic and these can break off while working around the engine"
The plastic connectors broke off in the hose from just moving it slightly - The hose is secured on what remains of the plastic bits, but I think its time to replace...
