so, one of the things i had on my back burner that I thought I had prepared for was the speed density ecu conversion and TTE420 install on my S6. i thought the car was in great shape and ready to go. not so.
i swapped ECU and injectors into an otherwise stock engine to ensure that i didn't kill the ECU with the soldering iron. i was just going to idle it and confirm life, then the turbo would be changed.
well, it barely ran, belched smoke and was just this side of flooding. so i guess i didn't have the right foundation yet! queue much investigating, well not much. it was clearly a vacuum issue as a speed density lives and dies on vaccuum.
i put it back to stock and got a guage on it and it was only drawing 7in HG (dunno what that converts to in real units). apparently the target should be somewhere around 18-20. after a bit of poking, i found a loose hose and a small tear in the turbo inlet boot. tightened the hose and hopefully sealed the tear (no sense in replacing as the new turbo uses a different size boot). i got it to 16/17.
now, in conjunction with this is the handy measuring group 000 in vagcom. it has 10 blocks of information which point you in the right direction for faults. i should note that there are zero fault codes and haven't had any throughout this process, which is why i thought i had a solid base i guess... at any rate, of the 10 blocks, 9 are now within spec. the 2nd one suggests i have an air leak between turbo and throttle. i have smoke tested the daylights out of everything and have not seen any smoke anywhere, even with the 2 issues noted above. my last thought about it is the idle circuit. is that considered between turbo and throttle? i have tee'd into that between isv and manifold for my vacuum booster. this could be causing the issue couldn't it...
i note that when i only slightly crack the throttle, vaccuum goes to ~22in... seems to me there's something going on with that branch of things?
that seem a logical interpretation to you guys?
one thing that has not been measured yet as i am waiting for the gauge to arrive is fuel pressure. i have a walbro 450 pump in it, it is possible it overwhelms the FPR's ability to regulate the pressure. to be determined at the earliest opportunity
