S2 ABY Water Cooled Manifold
  • orsum
    • May 2010
    • 1213
    • Home: United Kingdom Current: South Africa
    Guys I am looking for the correct size of the O Rings N0282034 Round Seal 15X2.5 S.
    Am I correct in saying they have a 15mm OD X 2.5mm thick. And the S equals a high temp material.
    There appears to be a leak on or near the banjo bolt, could also be on the front O Ring.
    New pipes have been fitted before but I will replace them again. Need to stop these silly niggles.
  • orsum
    • May 2010
    • 1213
    The correct size is
    20mm OD X 2.5mm thick. And the S equals a high temp material.
    15mm ID X 2.5mm thick. And the S equals a high temp material.
