so, i am back on the engine swap train given some life circumstances. there are 3 swaps in contention.
the first is an AAN which is period correct i suppose, but packaging will be challenging considering the parts i have left on hand.
the other 2 are more modern engine swaps with canbus architecture.
one is a complete b5 s4 that has rotted away thanks to canadian road salt. cheap, complete, and from a certain perspective easy to install from where i stand at the moment. just a lot of plumbing to sort. $ wise, by far the best as i can sell a lot of stuff i don't need for good money.
the last possibility is a c5 s6 4.2 BBD motor (engine only, not complete car) with ME7.1.1.
for the v6 and 8, i believe the questions are the same. Will the tach signal be in the canbus info or is that a wire coming out of the ecu that the b3 tach will understand (i have the 7A tach as well as an AAH tach)
for diagnostics code reading, will i need the gateway? reading mk5 golf diagrams (because i have them and should be similar from a network perspective?) seems to me that the powertrain canbus network is connected directly to the obd port so i should be ok? i'd still have the kline for the old abs any whatever else spoke to obd back in those days. i would have to snip off a diag plug from somewhere as well i suppose.
i know i will need the ecu to be reprogrammed for manual transmission as well as immo defeat (and maybe i'll make my life easier with secondary o2 delete)
i am trying to make up my mind in the next week....
thanks for any help
thanks for any help
