S2 ABY, Motronic PIN 32 PIN 49 PIN 50
  • CQ20VTurbo
    • Aug 2023
    • 5
    Hello everyone,
    I have a few questions about the ABY Motronic (see also attachment):
    There is an output for a boost pressure signal on the Motronic PIN 32, which is not used as standard on the S2 ABY.
    • What voltage and signal type/polarity is output there ?
      I'd guess it's an analog voltage, but I'm not sure.
    What maximum voltage and signal type (I suspect PWM?) should be present at
    • Motronic PIN 49 (input, from engine speed sensor G28)
    • and
    • Motronic PIN 50 (input, speed signal from sensor G22) ?
    Does anyone know more about this?
    Greetings from Germany
