Hello team,
I have been member for long time but due to different circumstances i was not active for while. I am glad to be back and I need your help
I am having an issue with boost pressure with my RS2 and I am running out of ideas, so I will appreciate if anybody can give me any input that might halp point me in right direction.
To the problem, car ist completely stock and it started having issues with boost levels going too high, basicly if I make pull in 3rd, 4th or 5th gear for example boost will goes to 1,6-1.8 bar and I notice that is not pulling right once it goes past 1.4 bar (which sould be max pressure as far as I know). Boost does fall back but it never reaches 0.9 bar level , here too it stays higher aroung 1.1-1.2 bar. It runs great on idle and pulls very strong until it goes past 1.4 bar and currently will not drive past 220- 230 km/h.
What I have done so far:
- Checked for fault codes with VCDS - no codes what so ever except one for crank sensor but I know that is ok when engine is not running
- Checked my boost gauge by adding another one and connecting near ECU - boost level same as my gauge installed in car permanently
- Checked for boost leaks using 1.4 bar pressure - one very small leak at IAC valve on conector side. I replaced this valve with new one coule years ago but it was barely driven since then
- Wastegate hast been rebuilt few years ago by very reputable person here in Germany, so I assume that is fine
- Checked membrane using vacuum pump on top port - hoding vacuum 100%
- Checked hoses from turbo to N75 and from N75 to wastegate , no issues
- Replaced N75 with brand new one from Audi, with same Part number and index - no change
- Checked - hoses from Intake manifolt to ECU including moisture trap using smoke maschine . no leaks found
- Connected another line temporarily from Intake manifold to ECU - no change, boost still too high
I at the point where I assume that MAP sensor inside ECU is probably defective becase it probably interprets actual boost level lower that it is. I dont know how to check this and I dont think I ever heard people having issue with factory MAP other that replacing it if they are runnung higher boost levels than sensor can handle. Also what is interested is that ECU does not set fault even boost reaches level way higher that it should, so to me that is another indication that MAP sensor is not doing its job, but since I am not sure I hope someone here can help
As I said I am running out if ideas, so any suggestions are more than welcome.
Thanks in advance
Berjamin
Thanks in advance
Berjamin
, right?
