Audi s2 (ABY) oil pressure sensor
  • NathanBS2
    • May 2025
    • 29
    Read a lot of posts about these sensors on here and from what I’ve gathered the aby engine uses two sensors. A 1.8 bar single wire and a 0.3 bar double wire.
    ive got these two sensors, product codes are:
    Single - 056919081E
    Double - 035919561
    on the double wire sensor it has the letters G and WK, are they in relation to what way the plugs go on?
    also on my new one it doesn’t say G or WK but has 0.5 and 0.3.
    ive attached images to show what I mean.
  • NathanBS2
    • May 2025
    • 29
    This gallery has 4 photos.
      • Dec 2017
      • 6010
      Don't worry too much. If you connect the two wires to the bigger sensor incorrectly, your aux gauge oil pressure will go right to max when you switch on the ignition.
      • NathanBS2
        • May 2025
        • 29
        I thought that might be the case just wanted to see others thoughts.
        • K Simmonds
          • Dec 2007
          • 7634
          As Dave say's it doesn't really matter if you get those wires the wrong way around, the Aux oil pressure gauge will simply read off the scale if they need swapping around...
          I've blown up the pic of the back of your new sender, it's marked 0 - 5 with a symbol for the gauge and 0.3 marked with a cross in circle denoting the switch, the G and WK will mean the same thing in German.
          1990 B3 2.0 80 quattro.
          1992 C4 2.8 Avant quattro
          1994 MTM RS2.
          1998 B5 TDI quattro Sport.
          2000 B5 TQS.
          • NathanBS2
            • May 2025
            • 29
            Well fitted the switches and the twin cable sensor was wired in. Turned car on and gauge flew straight to max so swapped them over and tried again and went straight to max again just in a sweeping motion this time?
              • Dec 2017
              • 6010
              Sounds like you have good pressure then. To test properly, warm it up. Hot idle should be around 2 bar.
              • NathanBS2
                • May 2025
                • 29
                Yeah ive still got to do an oil change and change the filter too
                • NathanBS2
                  • May 2025
                  • 29
                  For anyone who needs both sensors for
                  the aby engine these are what I bought and both are working perfectly.
                  This gallery has 2 photos.
                  • JayCab
                    • Mar 2025
                    • 196
                    Good old Prestige Motor Services. I've used them a lot. Genuine NOS is guaranteed but the markup on some parts is pure mafioso.
                    • NathanBS2
                      • May 2025
                      • 29
                      I’m just happy that it’s all sorted
