Fuel pump?
  • quattro estate
    • Aug 2015
    • 188
    Fuel pump?
    The cam sensor on my ABY engine is working properly and with nearly 5volts across 2 and 3 connectors
    I’ve loosened the fuel pipe to the fuel rail, should fuel squirt out with force? Fuel appears to dribble out while cranking
    who reckons I’ve got a pump problem?
    while cranking I can feel the f/pump relay clicking inside, I guess that’s doing what it should be doing
    thanks for any help?
    • Dec 2017
    • 5987
    Yes! You should get a good steady flow.
    • RedV6
      • Jun 2026
      • 69
      As above and you should hear it prime for a few seconds when you first turn on the ignition prior to you turning the key to the start position
        • Dec 2017
        • 5987
        Sorry, incorrect. The ABY doesn't prime on ignition like other VAG cars.
        • RedV6
          • Jun 2026
          • 69
          Ah. Apologies. It really does prove that most of us learn something new every day..!!
          • JayCab
            • Mar 2025
            • 195
            Mark 4 Golfs prime the fuel pressure on door opening. Great idea. They also have weak door microswitches that break, that are encased within door latch modules inside the door shell.
            Ingenious piece of VAG design. You get a no-start problem which solved by stripping the door right down to the latch internals and cracking out the soldering iron…
            …ask me how I know
            • JayCab
              • Mar 2025
              • 195
              Speaking of ingenious design…guess what happens if the brake light fuse on an Automatic Cab blows
