MB quattro
  • Crasher
    • Nov 2018
    • 163
    MB quattro
    1988 Type 85 quattro – thermostat failure, broken in two places. Any ideas?
    I’ve had a very odd failure that I’ve never encountered before, and I’m hoping someone might have an explanation.
    We have an ’88 Type 85 MB quattro in for extensive work. One of the major problem areas was the cooling system, where virtually everything was worn out and the system was full of rusty sludge.
    I removed both radiators and had two new ones made. I also replaced the water pump (Febi), the block-to-water-pump stub pipe (new genuine), and the water transfer pipe (new genuine from Tradition). All the sensors were replaced, and I restored both water housings and the rear angle pipe. I also checked and ultrasonically cleaned the heater valve.
    I flushed the system using a compressed-air/water gun. The heater matrix was particularly stubborn to unblock, but I persisted until the water ran clear. The amount of rust staining left across the car park was something I’d never seen before!
    I then reassembled everything, leaving the radiator circuit bypassed, with no thermostat or expansion tank fitted. I filled the engine and cooling system with a strong mixture of Bilt Hamber Deox-C and distilled water, then brought it up to temperature a couple of times a day for two weeks.
    After that, I flushed everything again using the air/water gun and blew the system clear.
    I fitted the new radiators and ran the VW genuine 052 525 A2 cleaning solution (nearly £200 for the kit) with distilled water for 20 minutes, with the cooling fan operating. I then flushed the system again, and an unbelievable amount of rust came out once more.
    Next, I sealed the system and filled it with the neutralising chemical, ran it up to temperature again, then drained it and flushed it with air/water before blowing it through with air alone.
    I vacuum-filled the system with distilled water, ran it up to temperature, drained it again and blew it clear once more.
    Finally, I fitted a genuine Wahler 069 121 113 thermostat from TPS and vacuum-filled the system with a 40% G12 Evo and 60% Quantum mixing water mixture. I brought it up to temperature, and everything appeared perfect.
    I drove the car for a few days, then noticed steam on the rear of the windscreen. The blower fan was also making a terrible noise, so I replaced it and checked the heater matrix from above. Everything looked fine.
    A couple of days later, I went to retrieve the wheel-alignment paperwork from the passenger footwell and found it wet, with sticky red coolant on it.
    I dropped the driver’s glovebox and could see coolant dripping from underneath the heater box. As the matrix is the same as the Golf Mk1 unit, I had a Nissens replacement in stock. I removed the pedal box (again!) and replaced the matrix.
    I then ran the car up to temperature, drove it home on two consecutive evenings and gave it a good run. The heater output was excellent, and the engine reached operating temperature within a few miles and stayed there.
    The customer subsequently collected the car to go on the Quattro tour. About an hour later, he called to say that the temperature was dropping and the heater was blowing cold.
    I wasn’t prepared to let him continue driving it in that condition, so he returned, collected his GT instead, and went on the tour without his not a quattro, missing a propshaft and rear differential. EXTREMLY embarrassing for me.
    I ordered another thermostat and O-ring and then spent the next three days worrying about what had gone wrong.
    Yesterday, I removed the thermostat and, to my horror and disbelief, found that it had broken in two places and was stuck fully open.
    I simply cannot work out why this has happened. The thermostat was a genuine VW from TPS Wahler part, and the system had been thoroughly cleaned and flushed before it was fitted.
    I’ve fitted another thermostat and am testing the car again, but I’d really appreciate some input from anyone who has encountered anything similar.
    I checked the thermostat housing by feel as best I could (I should have used my borescope) and couldn’t detect anything obvious. The stub pipe is below the machined surface and appeared clear, and the replacement thermostat sits in position without any apparent obstruction. As some will know, this area is very tight without a lot of dismantling.
    Has anyone seen a thermostat physically break like this? Could something in the housing or stub pipe be putting mechanical stress on it, or is there another possible explanation?
    At this point, I’m struggling to understand what could have caused it, particularly after all the work that went into cleaning and rebuilding the cooling system.
    Any thoughts or suggestions would be greatly appreciated.
    This gallery has 3 photos.
  • k6kid
    • Dec 2010
    • 30
    My first reaction would be to send the thermostat back to Wahler for a material analysis with a list the work you did prior to the failure.I have used Wahler in my coupe and found them to extremely reliable, but i am sure they would be interested in tracking down the failure mode to prevent further occurances.
      • Dec 2017
      • 6017
      I once had one turn up damaged in the post and one leg was about to fall off. Luckily, I noticed before fitting. Its only a tiny spot weld on each leg that holds it all together.
      • Crasher
        • Nov 2018
        • 163
        We sent it back to TPS, I don’t know what will happen to it from there. I fitted a new one and all OK so far. What really makes me angry is I took out a working one but made by Motorad, thinking it would be superior. The whole episode made me look stupid to not only our customer but also my colleagues and business partner and that could turn me to a nasty reaction.
        • K Simmonds
          • Dec 2007
          • 7637
          I think I'd put that down to a defective part, I've never seen one break like that in nearly 30 years working on these cars, the heater matrix failing does't surprise me at all on a car of that age especially with the cooling system in the state you describe and as you've probably already concluded is just coincidence...
          Very embarrassing when running a business and extremely annoying after putting in hours of work and materials to do the job right, I'd be really pissed off as well!
          It'll be interesting to see what TPS have to say, I expect they'll try and get out of any liability regarding costs etc but worth a try.
          1990 B3 2.0 80 quattro.
          1992 C4 2.8 Avant quattro
          1994 MTM RS2.
          1998 B5 TDI quattro Sport.
          2000 B5 TQS.
          • Alburglar
            • Oct 2017
            • 65
            I've never heard of anyone trying to clean a matrix out, especially if you had one on the shelf.
            But I don't reckon any residual crud from the 'cleaned' (as best you could) matrix would have that effect on the thermostat, but who knows. At least it's easy to swap out.
            • Crasher
              • Nov 2018
              • 163
              The situation was trying to clear out the matrix or spend two days stripping out the pedal box to fit a cheap part, whilst being up against the clock due to the radiator manufacturer taking three months to produce the first version, which didn’t fit. Of course, a left hand drive car doesn’t have this issue as the pedal box is on the other side of the car, a job I could do in my sleep.
              • A1quattro
                • Jul 2006
                • 791
                hi i think you have been very unlucky regarding thermostat failure im interested to here manufactures responce this could well have ended much worse with a cooked engine, i know the owner of this car he realy deserves some good luck
