hi!
i saw on forum that there are many s2 owners whou upgrade their s2 to rs2 tehnic.
the questation is, how to upgrade s2 (aby) ecu to rs2? is it the best to find rs2 ecu or is it possible to upbrage ABY or AAN ecu to rs2 one?
thanks
valjo
Audi Coupe S2 1993
Audi V8 4.2 1993
Audi cabrio 1998
hi!
thanks
valjo
Easier to go to Mihnea/MRC and get them to remap your current ECU. You can send the unit to them and they will fit the correct map sensor (for higher boost pressures)and fit new chips that are suitable for your hardware
To convert an ABY or AAN ecu you need a 3bar map sesnor and the corresponding chips to suit the map sensor and the injectors you are using.
My MTM ECU, from an RS2, was an AAN ECU that MTM converted.
Alternatively buy an RS2 ECU.
Other option would be as stated above, get it mapped to suit what you have built.
