Lamda help
  • NZS2
    • Jan 2007
    • 26
    • Home: England Current: New Zealand
    Lamda help
    VAG-COM'd today to see what's causing my rough running.
    Got "00525 - Lamda Sensor - 29-10 - Short to ground - G39 - Intermittent".
    Should I get a new sensor or is it a wiring problem?
  • NZS2
    • Jan 2007
    • 26
    Lamdba shot?
    My engine's still running rough and I'm suspecting the lamdba to be the reason.
    Got 00525 fault code on VAGCOM. And when I unplugged the 2 Lamdba connectors today and went for a drive, the engine runs just as roughly - so this must mean the Lamdba's bust.
    Am I right?
    • dan_b
      • Sep 2003
      • 3670
      Lambda is bust yes - change it, it's a quick and easy job.
        Before you rush out and buy a new one, have you checked the fuse the lambda is on?
        It the same one as the ISV.
        • NZS2
          • Jan 2007
          • 26
          Thanks - went to check the fuses and can only see "Heating for Lamdba-probe" fuse 25 (not blown).
          I can't find the ISV fuse... is the Lamdba & ISV fuse outside of the fuse box?
            25 is the fuse if it's not blown then new lambda it is!
            • NZS2
              • Jan 2007
              • 26
              Cool.
              Hopefully a new one will make a big difference - the car's really lumpy, splutters and just not nice to drive. Exhaust fumes smell really strong too.
