The head is of and problems start now
    Its probably worth making a few calls to see if an engineering firm can replace the liner instead, would probably work out cheaper than a new block too
      Originally posted by madS2
      hi i think you should use the Victor Reinz head gasket kit as it is much thicker than standard.I've just done the head on mine plus pressure tested and skimmed to be on safe side,All in all £400ish so be prepared.
      Thats cheap mate. I've been quote up to £800 ( from somebody I thought would have been ideal for the job ( Non forum ) )
      • Jon441cc
        • Dec 2005
        • 2061
        Try these Lou, ive dealt with them a few times
        • s2dude
          • Nov 2005
          • 1631
          Originally posted by 220bhp
          Had my mechan'ic round to look at the head and he found another more sev'er problem, one of the linnings in the block seams to have a crack in it,its a straight line and can be seen in the pictures below. So it looks like I am in need of a new block, and an afull lot of help and incouragement ,or I think I might just reace for the revolver.
          What do I do now, new or recondistioned if so from where, do I try and find a second hand block, or sell the car and cut my losses. I have to say I am loosing the faith right now.
          ok. This is a mighty ******
          Difficult to know what to suggest mate. But DONT lose the faith
          Probably your best bet is to see if you can get the block repaired. Of course...the rest of the engine is going to have to come out now anyway so you can take it to a local engine recon/repair firm and see what they can do. Fitting a liner, rebore, hone and new piston rings may just cure your problems.
          Try ringing through this list and see if they can help?
          Enginer reconditioners and engineers in Ipswich
          If they cant, decision time. But I would ring ALl Audi n Bristol and ask them if they have a block or an S2 engine only (no running gear etc). Then you could drop that in, sell your remaining engine bits to recoup some of the cost..then celebrate or sell the car depending how p*ssed off you are!
          • 220bhp
            • 2578
            • Home: United Kingdom
            #20
            Anyone on here with a block for sale, I just feel that this one is jinksed,.wonder what the cost of a recon or even a new one would be, frightning I bet.
            • 220bhp
              • 2578
              #21
              I have found someone to do the head , but he says that the block is not worth doing
              so it looks like I defo need another bottom end,so the oppstions are new block =to much money, used and not reconditioned, excange reconditioned,if there is such a thing,or find a block and recondistion my self, may be for big horse power ,and use my RS2 money,or find some one to buy my car as it is and buy an RS2,or just take the easy route and shoot my self, or even worse think about buying a BMW, NO i CAN'T BARE THE THOUGHT, please help.
              • s2driveruk
                • 12696
                All Audi are a good place to start in getting a block i would imagine.....good luck
                1992 3b S2 Coupe
                • volcano rs
                  • Jun 2005
                  • 2265
                  i think shooting yourself is probably the cheapest option
                  • s2dude
                    • Nov 2005
                    • 1631
                    ok. Does the guy who says the block is not worth doing know how much a new one is?? (may be worth trying a few other places to see if they all share the same opinion?)
                    All audi as S2driverUk says is the best place to start. They may only have a whole engine though...so you could be looking at replacing the whole unit and flog you old one for parts....(or keep it)
                    Option two is to buy an AAT block and build a stroker motor Requiring cost of new conrods, stock pistons can be used if machined (only theoretical...not tried it) but you are entering the realms of a fair bit of work to build even a "stock" stroker motor (as in no big turbo etc). See the fabulous thread by Pisobiker.
                    The sell your car option Tempting at this time but think of the hours you have into it.Your neeeaaaarly there to getting her running right.got to be! if you did sell you would also stand to lose a lot financially but cutting your losses is one route?
                    The easy route to shoot yerself is tempting Im sure. But will prevent future RS2 ownership and enjoyment so bin that one off . Buying a bmw...well..Im a massive bimmer fan so I cant fault you there
                    Have you rung allaudi yet? also would certainly be worth PMing sal_s2 on the forum as he may have an engine
                    heres a few numbers:
                    All Audi - 0117 9494136 www.allaudi.co.uk
                    Four Ring Spares, Thorne near Doncaster- 01405 816661 www.4ringspares.co.uk
                    Audi4U , 01278 434141 www.audi4u.org
                    VW Audi Spares, 01903 850924 www.audivwparts.co.uk
                    • 220bhp
                      • 2578
                      #25
                      I wonder if anyone knows whether the s2 block is unique to the s cars,or is it the same block on some of the other I5s the cranck is the same on many I know,if they are the same shorly it would be cheaper, and easier to find. Anyway thanks for your help guys I can assure you its much needed and appressiated
                      LOU
                      • Jon441cc
                        • Dec 2005
                        • 2061
                        Lou, i think the block from a 10v UR (mc) will work, it is the same deck height as the all the I5 blocks (220mm) that is, but would need to machined to accept the pistons, crank,rods will fit. some other parts from the 3B block would need to be changed
                        sump, oil filter housing, ect
                        (MC) bore size is 79.5mm (3B) = 81mm
                        Hope this helps
                        • Billy the fish
                          Banned
                          • May 2006
                          • 12
                          Interesting advice there, just be careful Lou, he'll probably come back on when your trying to sell your car and tell everyone it's a shed
                          Only words though, right
                          • s2dude
                            • Nov 2005
                            • 1631
                            Return of the patheticons
                            How sad
                            • 220bhp
                              • 2578
                              #29
                              H'M
                              • volcano rs
                                • Jun 2005
                                • 2265
                                hello billy the shark sorry i mean fish .long time no speak
