My CQ has a 3b motor, a K26 6412 and an RS2 exhaust manifold. No other upgrades so far. Though, I have been accumulating pieces for an upgrade. So far, I have the following items:
* mtm chip
* 3 bar pressure transducer
* harder wastegate spring
* 7A exhaust cam
* RS2 MAF
I am not into changing rods voluntarily or involuntarily, my goal is not to exceed 325 horses.
I have been reading posts on different forums regarding pressure transducers and the concensus seems to be that a 2.5 bar pressure transducer is sufficient for a 3b engine with stock rods.
My questions are:
1. I am not sure the basis of my mtm chip; I pressume that it's to be used with the stock turbo and fuel system. If this is correct, would the car run properly if I use the mtm chip with the 3 bar pressure transducer or should I install a 2.5 bar pressure transducer instead? Also, is there any way for me to tell what the requirements under the mtm chip, i.e., 2 bar transducer, etc... I was going to purchase a 2.5 bar pressure transducer until I read this post.
2. Considering the goal of 325 horses, of all the items that I listed above, which items would be recommended to be used? Please comment on appropriate fuel system changes as well. I have been thinking about a 7A pressure regulator without larger injectors, if I can get away with it. Otherwise, I'll get a set of 42 pound injectors.
Thanks for your comments,
Pedro
* mtm chip
* 7A exhaust cam
* RS2 MAF
My questions are:
Pedro
