Hp vs Intercooler size
  • Albie S2
    • Oct 2004
    • 138
    • Country: South Africa
    Hi
    How do u dertermine the zise for a intercooler if u run 400hp
    Thks Chris
    www.cardomin.com/member/745893
    Chris,
    It is more than just the size you need to consider, also look at the pressure drop across the IC, how much time will be spent on high boost, the efficiency of your turbo, ambient temp and where the car will be driven most of the time e.g. on track, on the road etc
    • Jay
      • Jul 2004
      • 599
      At that BHP the RS2 would be a good choice and easy fit but if you think you will in the future go up on that level of BHP then may be a ebay cooler like the one in bo's thread.
      Jay
      • s2_bo
        • Oct 2005
        • 6067
        Jay
        Yeah, they are good quality, big and cheap.I can supply crossmember too so its easy enough to fit
        91 S2 coupé - RIP
        98 S8 - Luxury barge
        • Albie S2
          • Oct 2004
          • 138
          cooler
          I have a cooler that is 300x230x68cm will this work ok,
          • Albie S2
            • Oct 2004
            • 138
            another
            another
              Anyword on the kits Bo? :mischeif:
              • Albie S2
                • Oct 2004
                • 138
                Cooler
                Last one
                  Should be fine, may be a little small for high hp
                  • Knight Rider S4
                    • 3541
                    Is the standard one not bigger than that??
                    93 S2 Avant Parting
                    91 URQ RR
                    02 A4 tdi Avant
