coolant temp warning
  • s2driveruk
    • 12696
    Coming home tonight and got the temp warning light come on. Sh*t myself but on getting home and checking coolant was where it should be and oil seemed fine too, no contamination so i guess its a gremlin but any idea's where? I thought the one in the base of the coolant expansion tank but any other pointers would be good.
    David
    1992 3b S2 Coupe
  • Dan_s2_coupe
    • Aug 2006
    • 482
    Try pulling the plug off the bottom of the bottle some times the sensors leak and can fill the connector up with gunk and corrosion
    I would check that first
    • s2driveruk
      • 12696
      top tip cheers Dan. new tank is on order anyway as it's brown as usual so i can't see the fluid level without removing the cap...
      1992 3b S2 Coupe
