what is the part number of this part?
  • timucin
    • Nov 2003
    • 869
    • Country: Turkey
    a friend told me that something under this part can be broken and that can be the reason of my engine.but i need to know the name and part number of this item
    help needed
    Quattro
    do you mean the harmoic balancer pulley on the crank? or the bolt holding it on?
    • timucin
      • Nov 2003
      • 869
      • Country: Turkey
      there supposed be a part under harmonic balancer, belt goes on top of it....thats what i ve been told... i ve never rebuilt an audi engine
      Quattro
      • timucin
        • Nov 2003
        • 869
        • Country: Turkey
        im not talking about the pulley.. is there any other sensor or stuff there?
        Quattro
          oil pump?
          • timucin
            • Nov 2003
            • 869
            • Country: Turkey
            LOL , Greg i dont think its oil pump or balance or pulley. i thought may be there is a sensor or something there.... may be not like i said i dunno.
            may be my friend who send this picture is making fun?!?!?
            anyway forget about it
            thnx for help try
            Quattro
              only reason i said oil pum is you have the pressure relief valve etc built into it and its fitted behind the crank pulley.
              • Doug_RS2
                • 3847
                Are you not getting the cam pulley mixed up with the crank pulley? There is a sensor behind the cam pulley.
                • timucin
                  • Nov 2003
                  • 869
                  • Country: Turkey
                  no,
                  i didnt make that yellow mark, picture came marked from an engine tuner in germany
                  Quattro
                  • SteveH
                    • 4460
                    Timucin,
                    You mean the cam belt wheel that attaches to the rear of the harmonic balance pulley? This part has the key that locates into the crank nose. I had this break off on my motor
                    Part number - 034 105 263 A
                    Probably best to replace the four allen headed bolts that secure it to the pulley too.
                    Part number - N 014 726 3 (M8x30)
                    If the keyway is damaged or the cam belt sprocket, you could experience problems with your cam timing.
                    HTH
                    Steve
                    91 Modded 3B
                    14 A6 Avant Black Edition
                    • Corey
                      Banned
                      • Sep 2003
                      • 2793
                      It's called the timex pulley. The key usually breaks due to some idiot trying to undo the pulley bolt while holding the engine on the transmission rather than the correct Audi tool (2084).
                      I would change it at the same interval you would a cambelt.
                      Is it worth risking your engine for a £30 part?
                      Corey
                      01636 822288
                      • Stick Insect
                        • Dec 2003
                        • 2338
                        Hi Corey,
                        I'm about to change my cam belt, what does tool 2084 look like? Can I make one or is it too complicated? I have access to good engineering facilities, no time but access all the same.
                        I could knock one up and take it to the garage meeting so that people could use it. I noticed a couple of people talking about cam belt swaps there.
                        David
                        • Corey
                          Banned
                          • Sep 2003
                          • 2793
                          I made my own, I have the drawing somewhere.
                          The Audi tool is actually made from 2 pieces of steel welded together, I machined mine from solid.
                          I will post it here if anyone wants it?
                          Corey
                          01636 822288
                          • timucin
                            • Nov 2003
                            • 869
                            • Country: Turkey
                            Originally posted by SteveH
                            Timucin,
                            HTH
                            Steve
                            himmmm cam timing problems....
                            possible...
                            Quattro
                            • Albert
                              • 1500
                              • Country: Poland
                              Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
                              those 2 adresses usualy help
                              AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
