Air con
  • zombie1709
    • Apr 2007
    • 29
    Air con
    hey people, im new, im about to buy an s2 coupe and its had alot of work to it, had engione rebuild, larger turbo n sduff but theirs one thing that im a bit wary of hes said that the airconditioning has been removed, but easily replaced, is their any reason why he would removed it? also is it an easy job to put it back? cheers
  • Rusty
    • 18953
    Usually removed as it can get in the way of tuning bits like a larger rad, different IC or because it's stopped working and he couldn't be bothered to fix it. My AC has never worked and I keep meaning to fix it but there's always something else that comes up and steals the money away!
    Re-fitting it would require assessment of the seals and components such as the condenser (mine's knackered) but it would be a couple of hours work to bolt it all back together. Then get it pressure tested and re-gassed.
    If the rest of the car is top-notch then I would not let it worry me as it's a minor detail and not uncommon to have knackered AC on a 10+ year old S2!
    HTH
      The reason is the price of the aircon parts, you could be easilly looking 1k in replacement parts alone!
      • zombie1709
        • Apr 2007
        • 29
        aaa i c, so its not realy a problem en? thanks allot.
