Anyone knw how much a new 3B pulley is? Not too keen on fitting a secondhand one as it'll be a minimum of 16 years old...
Crankshaft lightening
I recommend http://www.pk-motorsport.de/ for the crank lighteningAKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.netComment
There are many stories of balancing the 5 cylinder engine. The dynamic zero balancing method with variations
- balance all eng. parts to zero separately and then add them together and fine tune balancing the package again to zero
- with/without the bobweight %-approach
etc.
Some googling:
Inline5 should have section here:
Using balancing machines with modern SW and balancing station, but:
Turner Technology manufactures the original mill mounted balancer. State of the art controls and software give great accuracy. Balancer upgrades available.
CWT Training video collection:
Lecture for applying the theory later for inline 5 as homework:
Inline 5-cylinder engines and their balancing:
" it generates end-to-end vibration like 3-cylinder engines, because piston 1 is not in the same position as piston 5, and piston 2 is not in the same position as piston 4. Therefore both ends of the engine will vibrate up and down with respect to the engine center. "
http://www.vibratesoftware.com/html_...der_engine.htm
Article "The Balancing Act” Balance the design, or design for balance ?" tells more
http://www.tuev-sued.de/uploads/imag...08_smith_e.pdf
page 10
- dynamic balancing table approach
- section 4.3 5 cylinder case with measurements
Means and method of balancing multi-cylinder reciprocating machines
http://www.freepatentsonline.com/4545341.html
Balancing of the second order couple of a 5 cylinder in-line combustion engine
http://www.freepatentsonline.com/EP0462411.html
(use translator)
5-Cylinder Inline Design Project
http://sun-valley.stanford.edu/~hlj/projects/engine.doc
The article "Balancing act" has link to this company in UK
http://www.vibrationfree.com/
http://www.vibrationfree.co.uk/C&SC%...SPECIALIST.pdf
- most probably a good choice based on found articles
Is there some S2 forum experiences from vibrationfree company to Audi 5 cyl engine balancing ?
DE Balanced:
http://www.pk-motorsport.de/Gallerie...urbelwelle.JPG
http://www.bamotec-symt.de/motorenteile.html
a long feinwuchten story in Meckis forum:http://www.meckisforum.de/phpBB2/vie...welle&&start=0
PS.
googling also found the 5 cylider mega stroker: The 3.0 liter OM617
Nice links!
Slightly o.t.: A 5 cyl engine with even more displacement here (3653cc 102mm stroke x 95,5mm bore
) GM LLR: http://en.wikipedia.org/wiki/GM_Atlas_engine#LLR
Leif-Helge
-91 S2 VEMS and Comp Turbo
-12 B** 530XD Touring "S2 parts transporter, and daily driver"Comment
Balancing done in practice (no lightening) here:
http://www.s2forum.com/forum/showthread.php?t=43652Comment
to get the maximum weight off the crank, should the counterweights match the weight of the piston rod assy? or not relevant if the flywheel and front pulley is balanced to counteract the missing weight?
the flywheel has a much larger diameter than the crank so I'm guessing that drilling and adding heavy metal slugs on one side and just drilling the other would give enough balance on removing quite an amount of metal from the crank.
How could you even begin to work out how much metal is "safe" to remove before you've gone so far that it can't be balanced because the flywheel doesn't have the capacity to do so.
And which would provide the "smoothest" engine. balancing the rods and pistons to the counterweights or removing as much as possible from the crank and using the flywheel to balance?
Volcano ABY coupe
AntComment
