My S2 ABY has an occasional power loss problem which is VERY frustrating, and I wonder if any of you can help please.
WHEN : Like all good faults it does NOT happen ALL THE TIME, but several times a week, which is painful as hell.
SYMPTOMS : As you accelerate firmly, taking her over 3,000 -4,000 revs, the car suddenly "kangaroo jumps" as if the fuel is being cut, then flowing, then cutting again... when this happens you can accelerate VERY slowly and smoothly, but anything even part-way interesting causes this problem.
OTHER : If I depress the clutch and just rev the engine, it revs fine to 6,000 + revs with no faultering...so problem only seems to happen under load
AND : When it's happened I've sometimes switched off the ignition and restarted, and it's clear and fine again.
(note: on drives where this fault does not happen, you can stamp on the pedal, and enjoy the full turbo experience...and she takes off like Concorde)
Any ideas please?
Any ideas please?
