cam cover cap head bolts
  • s2driveruk
    • 12696
    Hi,
    Does anyone know the dimensions of these are I want to replace them when i get round to changing the gasket. Also would there be any issues in using s/s bolts are replacements?
    David
    1992 3b S2 Coupe
  • LHD_Kid
    • May 2006
    • 3695
    I used stainless when I replaced mine with no problems so far, so far as sizes go, I could only buy 50mm M5 (I think) and I had to cut 4 of them shorter....
    I will check tomorrow on sizes if nobody with the specs at their fingertips posts up...!
    Chris
    Wrong size, see my lower post... I have checked today...!
    • s2driveruk
      • 12696
      Cheers chris
      1992 3b S2 Coupe
      • martinjs
        • 3205
        M6 David, cant remember the exact lengths (should be in the family album) Yes you can use stainless, i did.
        I used this place for all my bolts etc.
        • s2driveruk
          • 12696
          thanks Martin
          1992 3b S2 Coupe
          • LHD_Kid
            • May 2006
            • 3695
            I just checked my Namrick invoice for those bolts, they are indeed M6... I bought 2 50mm ones and 4 25mm ones... for the cover
            (I also got 6 No. 25mm M6 for the throttle body, and plug cover, also well worth doing if your ordering from Namrick is 6 No. M5 x 50mm plus washers, and you can change the wastegate cap screws too for stainless... much nicer...
            (This is where I was getting confused, M5 and M6... )
            HTH
            Chris
            • s2driveruk
              • 12696
              good idea! I can't go monster power but i make make it look the danglies
              1992 3b S2 Coupe
              • LHD_Kid
                • May 2006
                • 3695
                I remembered I had to cut them down.... the family album lists the cam cover bolts as 4 @ 20mm (I had to buy 25mm) and 2 @ 48mm (had to buy 50mm)
                Remember to get washers where needed, also sold in stainless...
                You have the same as me... I have no funds for super power, but it sure looks nice under there...!
