Fuel rail problem
  • AudiCoupeParts
    • Feb 2007
    • 347
    Fuel rail problem
    I have an Rs2 Rail and FPR and fuel up to the FPR. THe fuel does NOT get past the regulator to get to the injectors. What would cause the FPR to not let the fuel pass???
    Anyone?
    THanks....
  • DJones
    • Jun 2005
    • 2020
    Sounds like your pipes are crossed..
    Fuel should get to the injectors before the FPR.
    • AudiCoupeParts
      • Feb 2007
      • 347
      Hi.
      THanks for your response.
      So, does the "incoming" fuel from the tank go to the pipe that is at the end of the RS2 fuel rail?
      It feeds the injectors and then the remaining "unburnt" fuel passes through the FPR and then back to the fuel tank?
      Why would the fuel need to be regulatated after the passing by the injectors and on it's way back to the fuel tank?
      I don't understand that.
      Could you explain...
      Thanks again.,
      joe
      • mcandmar
        • Apr 2004
        • 5118
        Sounds right to me, If you think about it the fuel rail is pressurized by the fuel pump pushing fuel against the regulator on its return path to the tank. If you removed the regulator you would'nt get any pressure as the fuel would just flow back to the tank. Its the bottleneck if you like that builds the pressure.
        Reason it sits after is because the fuel rail is the part its trying to regulate pressure on. If it was before the rail it would only regulate the pressure from the fuel pump to the regulator.
        Hope that makes sense...
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • AudiCoupeParts
          • Feb 2007
          • 347
          Yes!!!!!
          YOu are all right!!!
          I replaced my fuel lines from the tank back and I connected the feed to the return and vice-versa. :
          Car fired right up!!!! God I feel like such a dumbass!!! :
          THanks again for all your help guys!!!!
          Regards,
          joe
          • DJones
            • Jun 2005
            • 2020
            Glad its sorted.
