UrS4 92. AAN. RS2 turbo, 7a cams, RS2 injectors, etc.. RS2 ECU, chipped.The car was running ok for a year in this setup.
For one and a half month the car wasnt driven at all.Problems appeared suddenly. Sympthom is power loss after 4500-5000rpm.
ECU moves ignition later, after 4500rpm. Looks like knock sensors do their job.
VAG-tool and VAG-com dont show errors at all. Fuel pressure, pump, injectors, pressure regulator - ok. No boost leaks, no problems with sparks or ignition coils etc.. No problems with fuel or boost..
The only wierd thing i noticed is that if i disconnect one or both knock sensors - ECU doesnt store any fault codes, and there is no difference in car behavior with or without knock sensor(s).
(Both sensors are new). I also double checked wires from Knock sensors to ECU.Any ideas?
Im trying to solve this problem for a month...
Please help...
this is a screenshot of VAG-Tool, acceleration in 2nd gear.
Green is ignition
Purple is RPM
Yellow is lambda.
Blue is coolant temperature.
PS please excuse my bad english - i didnt have any practice for a couple of years..
and a strange sound in exhaust, as if ignition was too late..
