Hi everyone,
While dismantling my exhaust to fit the stock exhaust back on ( stupid Belgian laws won't let me pass MOT without my cats ), I checked the hotside turbo shaft and whaooow, 15000km since fitted from new and already about a small mm of play in the turbo shaft
Phoned Doug right away at MRC and he says that it's perfectly normal and not to worry... Said it's because it's not a ballbearing turbo and the turbo was completely cold also when I checked it. Said that when oil is flowing and the turbo is hot, there wouldn't be any play...
Of course, I can't check this when the turbo is scalding hot and the engine is on...
Any can confirm / infirm ? Turbo is still under warranty so....
Many thanx !
David
Many thanx !
David
