3B fuel pump relay location
  • terrybullwon
    • Mar 2006
    • 8782
    My fuse box cover does not show me the location of the fuel pump relay, and the family album gives a relay number that i do not have
    Can any one point me in the right direction?
    Cheers James
    Chef
  • terrybullwon
    • Mar 2006
    • 8782
    Top left to right
    204 214 214 275 213 214
    204 x 229 215 fuse blanks 214
    215 is in the space 10 where the fuel pump relay should be
    Any ideas???
    Chef
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      It should be in the middle of the front row of relays IIRC. 215 is the one I think. It should have a socket for a fuse on top. The same goon that told you a pipe was missing off of your wastegete cap, will probably tell you there is a fuse missing there.
      SS
      • terrybullwon
        • Mar 2006
        • 8782
        Cheers Stu,
        i have that one, i think its dead, if you link fuse 13 to the battery the fuel pump fires and so does the cold start but if you dont, there is nothing
        Cheers James
        Chef
