Hi all S2 Members
Help needed here, i am still having a few problems with my S2, replaced WGFV Valve, Replaced all vac pipes with Silicone, Replaced Main Turbo Inlet Hose, due to split around neck which connects to the end of the Turbo, Checked Wastegate Diapragm with no preblems there, Temperature perfect, Idling Perfect, but Boost is sometimes at 5 PSI and other times no more than 9 PSI, hence replacing WGFV Valve etc, done David H Mod aswell.
Set off in 1st gear and the car rips through that gear, put the car into 2nd and then the acceleration is like someones holding the front of the car back, put into 3rd, 4th and 5th, same thing with only 9 PSI Maximum and no overboost.
Is it worth checking the MFTS Sensor???? i know the procedure for testing but couldnt get at it earlier today, what else could it be ???
I will say this though, Dizzy sounds slightly noisy??? could this be causing hassle at high revs, although this wouldnt be causing boost pressure loss would it??
Any help would be appreciated folks
Regards Audimaniac
Regards Audimaniac
Bad teminolgy, water manifold / water rail.
