RS2 engine rebuilt for my Urquattro
  • Jaap
    • Oct 2003
    • 258
    Hello,
    I´am just rebuilding my RS2 engine, becaus of the restauration of my Urq is the engine out.
    The best time to give it better innitials.
    At first the engine does becomme SPM rods.
    The flywheel is replaced by a Alu one whith a Sachs MS clutch.
    Also laid my hands on a set of Porsche Bi Turbo fuel injectors icw 044 MS pump.
    A SQ MAF and a set of NM cam´s are waiting to.
    The engine room adapted to fit a RS2 airbox.
    Also want to have a EM like the 034 RS rep.
    Now i want to decide wat´s the best turbo GT 3071 or the GT 3076.
    So i somebody can give a good advice or has some tip´s I´dd like know..
    Hope to get 450-470 Hp....
  • Petya
    • Sep 2004
    • 89
    Where did you get NM cams? I wanted one pair.
    "you don't make history by following the rules, you make history by sizing the moment..."
    • Jaap
      • Oct 2003
      • 258
      NM Cams
      Did bought them on a German Audi forum...(Mecki's)
      But they are very rare
      • sal_s2
        • 1287
        What intercooler will you use and where will you mount it?
        • Jaap
          • Oct 2003
          • 258
          Home brew
          Just a home brew, but bigger than RS2
          • Jaap
            • Oct 2003
            • 258
            Ic
            The front has become again stock.
            But the IC becomes on the same place again.
            The AAN intake is adjusted now.
            So that was a pic of last summer.
            But are there some advice´s on the turbo??
            Greetz Jaap
            • Jaap
              • Oct 2003
              • 258
              ic
              Pic of IC
              • Jaap
                • Oct 2003
                • 258
                New wings on the ur
                The most resent pic.
                • spink
                  • 4382
                  think you could almost buy a new 7a ex cam for this price
                  http://cgi.ebay.co.uk/ws/eBayISAPI.d...2952&rd=1&rd=1
                  • Jaap
                    • Oct 2003
                    • 258
                    NM and Turbo
                    Yes indeed they arn´t cheap.
                    Also bought a turbo.
                    Is gona be the GT 3076 turbo, with downpipe 3" and a custom EM.
                    So now find a man wo kan and want to reprogram the motronic...
                    Let me know if you want and can do it right.
                    Greetz Jaap
                      Fine choice of turbo sir, 0.82 or 0.63 AR?
                      Aronmatic had excellent results with the 0.63 although it's trickier to map over the 0.82
                      Depends if you want that lower kick or balls out HP?
                      • Jaap
                        • Oct 2003
                        • 258
                        Will go for the lower Kick...so it would be the 0.63 AR
                          Check
                          http://www.s2forum.com/forum/showthr...t=5399&page=15 Post 216
                          • Jaap
                            • Oct 2003
                            • 258
                            Uri
                            Very interresting.
                            So i have great expections about the end result.
                            greetz from Holland
