Turbo Frequency Regulator
  • Big_kev
    • Dec 2006
    • 159
    Having major problems with 3b not responding immediatley to the throttle. Have just changed wastegate diaphragm and this has not solved the problem. Have bought a Turbo Frequency Reguator form VAG parts (as was suggested) but cannot locate this. Could someone assist with a picture or something.
    Any other suggestions as to why the car is hesitating when throttled would be happily accepted. This does not just occur on WOT but during most phases of acceleration.
  • BrianSmith_S2
    • Jun 2005
    • 1342
    • Home: Northern Ireland Current: British Antarctic Territory
    This item is down the left side of the engine bay, in front of the air box, behind headlight, above the dump valve. its connected into the large bore rubber hose that feeds off from the MAF down to the turbo .
    Best i can do without a photo
    Brian
      There a quite a few posts on here on how to replace it search the forum for the word WGFV which stands Waste Gate Frequency Valve.
      • audimaniac
        • Feb 2007
        • 152
        It is if it is an ABY Engine, if it is a 3B Engine, its on the right next to the engine block side of the Turbo Intake pipe.
        • s2dude
          • Nov 2005
          • 1631
          Its in the same place on both
          It is being described by Brian as you look head on at the bonnet. Not from the driver seat!
          • Big_kev
            • Dec 2006
            • 159
            Cheers guys
            I did search through the forum for Frequency Regulator and found no hits. The trouble with searches is that if it requires full text matching and you don't know exactly the terminology it doesn't return any hits.
            thanks for the info and i will go and look now.
            • martinjs
              • 3205
              Does it mis-fire at all?
                As I said search for WGFV
                • Fat Audi 80
                  • 10547
                  Looking at engine. LHS, take Headlight out, remove plastic trim behind headlight and infront of airbox, peer inside and locate the WGFV attached to three pipes. Prise off pipe clamps and replace.
                  Reassembly is reverse of removal. (1 - 2 hours tops...)
                  Cheers,
                  Steve.
                  The Perfectionist
                  • Big_kev
                    • Dec 2006
                    • 159
                    Hi guys
                    No the car doen't misfire it just seems to stagger for a second before accelerating. A comparison would be somewhat like turbo lag but can happen at any revs.
                    • nigelm
                      • 150
                      Do check you haven't got loose plugs. Is very common.
                      nigelm
                      • Big_kev
                        • Dec 2006
                        • 159
                        Hi Niglem
                        Have checked all the plugs and leads that i can think of and all seem OK. I am wondering if one of my turbo pressure pipes is cracked. I have checked all the ones i think connect to this but don't know the full setup. If someone has a diagram of the turbo pressure pipes to check i shall do this as wel.
                        Thanks
                        Kevin
                        • Crawford_S2
                          • 1555
                          Sounds like a boost leak to me. Lots of threads as Jamo said, just a question of chewing through em really. Think everyone on here has had a boost leak at some stage.
                          Ragusa Coupe gone!
                            try this thread it may help
                            • Big_kev
                              • Dec 2006
                              • 159
                              Boost Kit
                              Guys
                              Cheers for your input so far. Have asked andyp if he has any Boost leak test kits left. Will check back with you if i find problem. Will now be looking for silicon hose to replace small pipes anyway. is this the 4mm silicon pipe.
                              kevin
