turbo + ??? EM
  • max_s2
    • Mar 2006
    • 498
    • Country: Latvia
    turbo + ??? EM
    Hi!
    I have 2 questions, maybe someone can help with ideas etc?
    1) I wanted to know what EM to use with turbo GT3071R A/R .63?
    2) Whats the difference between menu items of compressor housing and exhaust housing here http://www.034motorsport.com/product...roducts_id=725 ? Witch options best to chose for inlet and exhaust of this turbocharger?
    Thanks!
    Order from that link, You can use a Rs2 EM or any tubular manifold.
    It depends on if you want a K26 or T3 flange on the turbo
    • max_s2
      • Mar 2006
      • 498
      • Country: Latvia
      Thanks for answer!
      Maybe you meen the RS2 EM from this link http://www.034motorsport.com/product...roducts_id=529 ?
      I have heard, that RS2 EM are up to 420hp only. This one is better/modified? Some people say that its better if I set up a "spider" style EM, smth like this http://www.034motorsport.com/product...roducts_id=663
      Havent buyed any turbos yet so can anyone tell/show differences between K26 and T3 flange? Or it depends on EM that I'm plaing to set up?
        Originally posted by lv_max
        Thanks for answer!
        I meant standard RS2 EM and that it is only good up 420 is bullsh*t
        K26 is round opening T3 is a squarish opening, K26 is the stock Audi one.
        You need to decide which EM you want 1st
        • Ross
          • Aug 2005
          • 3399
          The RS2 EM hasn't really been proved that I'm aware of... I can attest to the fact it's fine at 430bhp and Doug can for 440bhp. Decide how far you want to push with power and then decide - I'd suspect that the new wagner RS2 equivalent will be your best bet if keeping stock-look is your aim, when it finally makes it to production!
          • max_s2
            • Mar 2006
            • 498
            • Country: Latvia
            Thanks Jamo! Got it.
            Ross: opz, error form me, sorry. re-readed message form one man, he told me that RS2 EM is fine up to 480HP not 420HP as I sayed, so it will be ok for the first try (I hope so).
            So.. if I use RS2 EM, then I need to order GT3071R with whitch one option of these:
            Originally posted by http://www.034motorsport.com/product_info.php?cPath=21_100&products_id=725
            3 Flange, Ford 5-bolt, Int. or Ext. WG
            T3 Flange, 3" GT V-band discharge
            T3 Flange, 3" GT 4-bolt discharge
            T3 Flange, T3 4-bolt discharge
            T3 Flange, 5-bolt Internal Wastegate
            Will I need to order smth more to get these two things together or it will be ok so far?
            And what you guys say about the RS2 replica EM ( http://www.034motorsport.com/product...roducts_id=529 ) ? Will it be enought ok? Or it's better to use stock one?
            • A80Avant
              • 10873
              • Country: Greece
              i got from 034 the 3071R with the K26 flange to use with the OEM RS2 manifold.hoping to make 430hp and later replace the EM with wagner's unit
              • max_s2
                • Mar 2006
                • 498
                • Country: Latvia
                Hmm.. so I gues that I need to mail them to make correct order for my set-up..
                btw, what's a wagner's unit? Some kind a brand or what?
                  Hi you'd order the turbo from the link I posted unless you are going to make your own water and oil lines?
                  As the OEM water and oil lines dont fit the turbo.
                  • max_s2
                    • Mar 2006
                    • 498
                    • Country: Latvia
                    For water and oil lines I'm planing to use this this set: http://www.034motorsport.com/product...roducts_id=297
                    • porkkis
                      • 1994
                      3071 in stock location will probably hit the side member if it has a bit larger turbine housing (as I presume it has) than 2871. 2871 is already really tight.
                      • rs2coupe
                        • Oct 2004
                        • 1782
                        • Home: Trinidad and Tobago Current: United States
                        So that means no room for RS2 airbox?
                        Cheers mis amigos,
                        _Anton
                        • porkkis
                          • 1994
                          rs2 airbox fits just. There will be less than 1cm gap between comp housing and rs2 airbox with 2871 and if 3071 has same size comp housing it will also fit.
                          Snub mount stopper plate must be adjusted to be firmly against the snub.
                          Btw I think 2871 with small hot side isn't a good choise for our engines. It tends to surge. A lot. I had to limit boost below 3000 rpm really much to avoid surging. 3071 should be better surge wise.
