So I picked up one of those bronze gears off ebay to fix my aging plastic gear rattle and had a question about the pin for anyone here who has actually taken theirs apart. Did you re-use the old pin? If looks like the fatter side won't really fit well in the bronze gear because it isn't wider on one side like the plastic gear was. Did you use a different type of pin like a roll pin? Thanks.
