Anti lag system
  • audiman
    • 4827
    Anti lag system
    Does anyone know of an anti lag system that can be fitted in conjunction with the motronic ECU????
    I have done some net searching, but didnt really come up with anything.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
  • Dubbedup
    • Jan 2006
    • 291
    Dont know where you would get such a thing, but I would love to be sitting at the traffic lights with that....POP POPPPPPPOP BANG BANG WAHHHHHHHHHH....
    The Chav's would **** themselves...
    • audiman
      • 4827
      I really want it for its anti lag properties, and not its popping noises, although they are cool
      Audi UR Quattro
      • AUDI COUPE 20V
        • Nov 2005
        • 251
        any info regarding remap?
        • audiman
          • 4827
          Will PM you when i have the info
          Audi UR Quattro
          • Faheemo
            • Feb 2005
            • 544
            • Country: South Africa
            I've got an anti lag system done on my S2, hold the revs above 5500 rpm in 1st gear and the car builds boost up to bout 0.2bar..
            Motronic ECU , car tuned by Frieling Racing here in S Africa, i sure minhea has the trick up his sleeve, no ?
            Car bolts off the line like a sick cat. Its got my rear Diff makin noises now..
            S2 Coupe fully built.
            10.9 1/4mile 0-100 in 3.5secs
            Precision 6262 turbo
            The Green Monster
            • Ross
              • Aug 2005
              • 3399
              Ever floored it with the brakes on?
              I did that once in the coupe... 2nd gear, 30mph, brake pedal mashed, throttle hard on, boost >1bar and then off the brake and WOT. It jumped off like a scolded cat, but after that i thought about my driveshafts, gearbox, diffs etc...
              Sure with a bit of heel/toe you could try it off hte line :-D I think i should listed to walter rohrl less lol.
              • andy112
                • Nov 2006
                • 133
                • Home: Poland Current: Canada
                s1 anti lag if you want to rebuild the head, but very $$$$$$
                • audiman
                  • 4827
                  thats not going to help me to get good times off the line LOL
                  I have never tried it, but at 30 in 2nd i dont have boost, not sure the brakes would hold it back if it did come on hard boost
                  Audi UR Quattro
                  • A1QSHIP
                    • Aug 2004
                    • 975
                    Brakes make more horsepower than engines :mischeif:
                    "Nulla tenaci invia est via"
                    • Baldy
                      • 469
                      • Home: Sikkim Current: British Antarctic Territory
                      fit nitrous with a boost switch to turn it off once the specified amount of boost is required so it only boosts before the turbo comes in fully
                      Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
                      0-60 4.9
                      1/4mile 13.5
                      • Audi_CQ
                        • 940
                        • Country: Norway
                        No way I can hold my car back with the brakes from 4000rpm and up
                        • urquattro-island
                          • Mar 2006
                          • 1915
                          • Home: Norway Current: Iceland
                          hmmm
                          last time i looked, brakes did not make any Hp at all
                          japanischer industriabfall nein danke!!
                          www.rackeltrim.se Icelandic Division
                          • denniselbows
                            • 740
                            hp is made by hienz now
                            never set your expectations to high that way you are never disapointed
                            • aspro
                              • Dec 2005
                              • 75
                              If anyone fancys ago you could run a megasquirt ecu hooked up to 2 extra injecors that fire directly onto the hotside turnbine blades.
                              Not a great idea unless you can afford to rebuild your turbo alot.
