Spot the mod
  • rj scotty
    • May 2006
    • 2195
    Spot the mod
    No its not blue powder coating
    Look a little closer
    034 Motorsport High output coil kit
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
  • topsparky
    • Oct 2005
    • 2014
    i've just got a set of those
    (cheers corey)
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
    • rj scotty
      • May 2006
      • 2195
      Your gona have fun fitting them
      Saying that you may have more space on the s4.
      They just, and i mean JUST fit in the space shown.
      Need to cut the rods down and have number 1 and 5 coils toching the brackets.
      Plug the loom end in befor doing the rod nuts up as you cant do it after.
      Other than that its an excelent bit of kit and the loom really good quality however the conections are free floating instead of fixed as on the original setup, not sure if this will cause problems with wire chaffing in the long term, watch this space.
      10 times better than the original flawed (put the coils in the oven) design.
      cheers
      Rich
      • pixsaudisex2
        • Sep 2004
        • 3110
        and how much have these ended up costin you.. if you dont mind me askin as well this is something im thinking about..
        • Corey
          Banned
          • Sep 2003
          • 2793
          No he's not
          On the S4/S6 they can be hidden from view for a totally stealth install
          Corey
          01636 822288
          • pixsaudisex2
            • Sep 2004
            • 3110
            or maybe mister corey will say what the damage is for these
            • Jas11n
              • 5067
              cheers
              Rich
              "flawed" after 12 years of use???
              2001 Avus Silver B5 RS4.
              1995 S2 Coupe - sold (sniff)
              • rj scotty
                • May 2006
                • 2195
                Yes they lasted 12 years but then failed and the cables went brittle.
                This setup won't let that happen.
                You just replace the ht leads.
                • topsparky
                  • Oct 2005
                  • 2014
                  Originally posted by Corey
                  No he's not
                  this is true when it stops raining i will take a photo
                  to prove it
                  :mischeif: :mischeif: :mischeif:
                  1. SHORT SHIFT KIT
                  3. H & R SPRINGS
                  4. BILSTEIN SHOXS
                  8. fmic fitted
                  • Acidburn
                    • 13459
                    So just out of interest how much was the high output kit? and is it just plug and play?
                    • topsparky
                      • Oct 2005
                      • 2014
                      here's the photo of the coil packs in my urs4
                      1. SHORT SHIFT KIT
                      3. H & R SPRINGS
                      4. BILSTEIN SHOXS
                      8. fmic fitted
                      • rj scotty
                        • May 2006
                        • 2195
                        looks good
                        how much room is there on an s4 !!!
                        • mcandmar
                          • Apr 2004
                          • 5118
                          Just noticed something, on our urs4 the battery is under the back seat
                          91CQ20v - Gone to a new home
                          93UR-S4 - The Magic Carpet
                          94S2Bus - The Emerald Express
                          • spink
                            • 4382
                            yours will have aircon,on the one i had it was under back seat also
                            • mcandmar
                              • Apr 2004
                              • 5118
                              Yes it does, that explains it then
                              Cheers, Mark.
