Hi!
I'm using a GTBB 35/40, with a K26 flange, bought if from ATP turbo.
I'm using machined 7a cams, the power is awesome, the car is like a mad cow with ecstacy
But I'm not happy with how "slow" the boost is spooling, I'm seeing 2 bar @ 5500 RPM, is this normal? I was led to believe that this turbo would spool around 4000-4500 RPM. Or might this be because of the cams?
The turbo is .70 A/R compressor side and .82 A/R turbine side (#10 exhaust according to ATP) , I have an option to go with .63 A/R , that would set me back on the top end I suppose, but I think that would be worth it just to get earlier spool.
Had the car driven on a track this saturday and the spool was "killing me" , but when I started to mash the tranny (putting it in first gear in a few slower spots) then I ran a few seconds faster.. But The GTBB turbos is supposed to be quick. A friend of mine is using a HX40 with a 1.8L golf engine in his GT quattro, he's seeing full boost at around 4000. I mean WTF????
I'm rechecking the cams now to see if I've done anything wrong, but considering the power the car is producing I'm sceptic that I've set the timing incorrectly. Maybe adjustable cam gears is the way to go now?
What kind of RPMs are you other 35/40 guys seeing boost at, if you're seeing it earlier, PLEASE tell me what kind of camshafts you are using
.But I'm not happy with how "slow" the boost is spooling, I'm seeing 2 bar @ 5500 RPM, is this normal? I was led to believe that this turbo would spool around 4000-4500 RPM. Or might this be because of the cams?
