Hi all
Some of you are probably aware that my S2 is for sale. At the moment it is having a problem with a no boost issue so I have decided to try and fix it. Parts I have brought are a MAF Sensor, WGFV, & MFTS. I have practically changed everything else so Im hoping one of these will cure the 5PSI max problem.
My question is how do I fit a MFTS, is it just screwed into the water rail?
I presume as it is screwed into the water rail I'm going to have water coming out when I remove this part?
I brought a MFTS as I heard this can effect boost as well.
If I do fix it the car might not be up for sale anymore, cause I can just see it being way to fun
Thanks All
Ian
Thanks All
Ian
