can anyone tell me what this noise is and where its from ...........as i rev no noise as the rev,s die off ........rattle ..............it comes from the top of the engine it,s not a bearing sound ..i dont think that would rummble?...............its been there for a long time any ideas?
rattling noise
Save a sound clip on your computer, go to 'GO ADVANCED' under the quick reply box at the bottom and then the 2nd option down the page will be 'MANAGE ATACHMENTS' up load your sound clip and it should* be in the reply!
* I reserve the rite to be incorect
Probably the longet S2 project in history EVER!
I have the same rattle and it either sounds like a heatshield vibrating or the dizzy gear. If you open the bonnet and listen over the top of the engine it sounds like its coming from the top of the engine but I am pretty certain its nothing serious....just slightly annoying.Comment
noises
yer, thanks mate thats the noise i think u r right........... seems its coming from the top as if from the pleneum chamber ........... the dizzy noise what would cause that ? i have put the 2 7a cams on last week ..............................is this a poss?Comment
Well I am not completely sure of the sound but I know that it is nothing serious. I can hear it by revving it to about 2k rpm and holding it or by revving it high and leting off the throttle.
If it is the dizzy making the noise, it will just be the gear which you can replace for a metal one off of ebay but the hardest part is getting to the dizzy and the gear to replace it.
I have been meaning to replace mine but I want a good enough reason to replace it first.
You just need to remove the dizzy... you don't need to remove any of the engine at all (although, if you can be bothered to remove the IM it helps...
also removing the ISV helps a little.... Its tight, and a right pain, but its not impossible...!!!
Its easier if the dizzy has been off before, as the tamper cover on the nut will have been removed...
search for dizzy removal, and lots will pop up...
'03 ZX12-R daily hack.... lots of nice bolt ons...Comment
I've had a search for dizzy removal but it doesn't seem to return too much.You just need to remove the dizzy... you don't need to remove any of the engine at all (although, if you can be bothered to remove the IM it helps...
