Crankshaft position sensor
  • a25c
    • 259
    Anyone got a part number for this?....also a good supplier as it is on back order from Audi with no supply date as yet!......€180......
    96 UrS6
    96 UrS6 Avant
    Previous:
    '87 coupe quattro, '85 90 quattro
    '95 S2 Avant '89, 200 quattro 1b
    '00 Allroad 2.7T, '02 S6 V8 Avant
    '96 A6 2.5 TDI quattro Avant.
  • terrybullwon
    • Mar 2006
    • 8782
    I got one from euro car parts @ £24.50 iirc
    HTH
    Cheers James
    Chef
    • a25c
      • 259
      Cheers James,I've e mailed them requesting the part so hopefully hear from them tomorrow!
      96 UrS6
      96 UrS6 Avant
      Previous:
        This may or may not help:
        http://forums.audiworld.com/s4s6/msgs/116988.phtml
        Dave F.
        • a25c
          • 259
          Many thanks Dave,that link has cleared a lot of things up for me..,euro car parts say they have the sensor and are quoting an Audi part number 078 905 381A,but the part number listed in the link is 034 905 381 ,whats the significance of the first three numbers?
          96 UrS6
          96 UrS6 Avant
          Previous:
            Well, to review, the AAN and ABY engines want a 034 905 381 = ignition timing (crank position) sensor in black and a 034 905 381A = engine speed (rpm) sensor in grey to tell the ECU what's what. All the five cylinder engine parts (as far as I know) start with 034 (hence "034 Motorsports" dedicated (mostly) to the inline five engines). The 078 engines (as far as I can tell) include the 2.6 and 2.8 litre 90 deg AAH and ABC V6's that I know came into production as early as the first C4 100s (in the 1992 model year). I suspect that a 078 905 381A engine speed sensor will be very similar to a 034 905 381A engine speed sensor. HOWEVER, unless the parts fellow could guarantee that, I would hold out for the 034 905 381A.
            Dave F.
            • a25c
              • 259
              Failure to start.....
              Finally got sensor off euro car parts €62 delivered,Gave it to mechanic to fit but it is still failing to start.The mechanic is now uninstalling the factory door lock activated alarm....
              96 UrS6
              96 UrS6 Avant
              Previous:
              • Pete Reeve
                • May 2007
                • 584
                I keep the right parts on the shelf www.quattrocorner.com
                Quattro Corner Audi OEM Parts
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Please before you start getting drastic with the alarm.
                  Check that the timming pin is still on the fly wheel, its a £0.37 part and mine dropped out, but i had already replaced the sensor as vag com kept throwing the fault up.
                  Cheers James
                  Chef
                  • a25c
                    • 259
                    Thanks James,I'll get on to the mechanic tomorrow and mention it!
                    cheers Robbie.
                    96 UrS6
                    96 UrS6 Avant
                    Previous:
                    • a25c
                      • 259
                      Mechanic got back to me tonight car is now running,when the new crank sensor was installed it cleared the fault code so thus eliminating the the timing pin theory,next was the factory alarm which they did a partial uninstall to see if the immobilliser was inhibiting the car to start....no joy there.Turns out the timing belt had slipped by 2 teeth and when reset the car started.5 weeks this saga has taken to resolve now I have to look forward to a big labour bill!
                      96 UrS6
                      96 UrS6 Avant
                      Previous:
