Antilag -- prodrive?
  • Chris5044
    • Feb 2005
    • 1663
    hmm I heard that prodrive for subarau offer antilag packages ... have they a different antilag setup to the ones that people discribe on here that damage the s2? .. I'm trying to find if its possible to have antilag but with less likely failure of parts
    I believe the 034 ecu has an antilag feature.
    • Billman
      • 4129
      VEMS too.
      Go Holset or Go RS4
      • pnanassy
        • Dec 2004
        • 287
        • Country: Hungary
        You have to understand how it works,than you will know that no matter which type you use it will highly stress some of your engine components.Depending how you set it up it can be better or worse...
        Peter Nanassy
        Custom Engine Management,and Electronic Fuel Injection solutions supplier , contact me for details.
        http://www.carstyling.hu/car_shower.php?id=19845
        http://www.youtube.com/watch?v=FYOVA_285Rs
        • Chris5044
          • Feb 2005
          • 1663
          ok which parts will it stress and who do i have to see to set it up reliably .. like the package prodrive offer for subarau ... hey better still why don't i see prodrive for it
          • pnanassy
            • Dec 2004
            • 287
            • Country: Hungary
            -exhaust valves
            -exhaust manifold
            -turbo turbine side all parts
            engine will get extreme thermal load ,thats why ECUs turn it off at certain engine parameters like CLT, EGT ,elapsed time,etc.
            The main question is why do you need it.Almost any good Standalone will do it for you.
            Peter Nanassy
            • aronmatic2
              • 2129
              • Country: Hungary
              Originally posted by pnanassy
              -exhaust valves
              -exhaust manifold
              everybody needs long flame and RATTATATA
              Real carbon parts for S2 and RS2. Check Carbondesign on facebook
              • pnanassy
                • Dec 2004
                • 287
                • Country: Hungary
                And periodic engine maintaince...
                Peter Nanassy
                • prosty
                  • Jun 2005
                  • 1114
                  ALS is only supposed to be used 5-10 seconds before launch, if you're smart that will make the engine last a while too, and if you have the power for that ALS is required for, you SHOULD know how to maintain and take care of your car. Or atleast afford to hire someone who can..
                  2004 9-5 aero
                  2009 Subaru Legacy Diesel
                  1994 Toyota Supra Eurospec 6-spd LHD
                  3-4 Audis in parts
                  • s2driveruk
                    • 12696
                    isnt half the fun learning how to get round the lag using the throttle and burying it early-mid corner for max exit speed....antilag seems a bit overkill unless your going into WRC
                    1992 3b S2 Coupe
                    • pnanassy
                      • Dec 2004
                      • 287
                      • Country: Hungary
                      prosty:
                      the correct term is "Launch control" for that,tough the way you achive it is very similar to
                      AntiLag.
                      Peter Nanassy
