Smoke under load
  • alg
    • Apr 2004
    • 1160
    Smoke under load
    Noted some oil use over recent months despite switching to 10-40w. Also noticed some oil spots on bumper after a 300mile round trip and the oil from top to bottom on dipstick.
    Never any smoke except usual white on cool damp mornings as water in exhaust burns off.
    Today coming round roundabout on Edinburgh bypass gave it WOT in second and covered the irritating car behind in blue-grey smoke.
    Checked all at home and the oil spots have reappeared on rear bumper.
    Car running well with full boost and no hesitation.
    To save guessing from folk
    1 No fault codes
    2 New lambda 12 months ago
    3 New MAF 12 months ago
    4 PCV cleaned and replaced
    5 Never had a boost leak and passed the MRC pressure test last year. Running well with no hesitation so seems unlikely.
    This is oil getting out under load ? turbo (original) ? valves (new short engine block prior to my owner ship under audi warranty so I guess original head)
    Alastair
    RS2
    Valve stem seals?
    • alg
      • Apr 2004
      • 1160
      Thats my guess Jamo Ta
      Alastair
      RS2
      • Rusty
        • 18953
        Try running 10W60 fully synth to prevent the oil breaking down under the extreme temperatures in the turbo and therefore being blown out the turbine.
        • ericd
          • Nov 2003
          • 1240
          Al,
          take out the lambda and have a look, mine's was covered when my turbo started going...
          • archiboy24
            • Sep 2003
            • 286
            Was it a right-hander round about by any chance? Likely a bit of oil getting up into the crank case breather hose and burning off. Not a big deal and it should go away after a little driving. If it persists though, then you may have to dig deeper.
            Ben
            Calgary, Alberta
            Canada
            1991 CQ e//S2 w/ RS2 spec 3B 20vt
            Panther Black Metallic
            www.moda-architecture.ca
            • alg
              • Apr 2004
              • 1160
              Thinking more about this I wonder if it is the PCV/breather system. I changed it two years ago . It did not have a great deal of cr*p in it. Turbo should smoke at idle and valve stems on overrun.
              Best go give it some beans and find out more
              Alastair
              RS2
              • Dubbedup
                • Jan 2006
                • 291
                Yeah take out the PCV and the flame trap and give it a good clean out...Takes a couple of hours, but the crap that came out of mine was mental...
                • caterpillar
                  • 2480
                  look in the ic and se if there are oil in .... if it NOT the breather system, it mostly the turbo: you can have soem play up and downs in turbo, but NOT in/out... thrustbearing and seal gone....i think its so in your engine.
                    Also check the spark plugs are in properly and the cam cover inner seal is in good condition. I had similar symptons last year caused by that
                    • alg
                      • Apr 2004
                      • 1160
                      MRC did these earlier this year. All looked good
                      Alastair
                      RS2
                      • alg
                        • Apr 2004
                        • 1160
                        Wiil do but no smoke today on WOT overrun and idle so who knows. Maybe I just cleaned out the crankcase breather system yesterday !!?
                        Alastair
                        RS2
