Its the engine speed or crank position sensor, goes in a little hole against the flywheel bro.
Ragusa Coupe gone!
As I said above it should go in the same alloy block as the other one. Perhaps this pic should help. As you can see they sit side by side. One is raised up slightly.
I think I can just make out the bolt thread on the other side of the alloy block.
Depending on the colour of the other end (grey or black) its either the engine speed sensor or the crank position sensor. See the URL for more details:
Didn't get a chance over the weekend but car runs fine so is probably one that has been replaced at some point in the past and i've just never noticed...
On the plus side my Son won another trophy for Karting this weekend
