When I floor the accelerator for the first time after starting the car the boost often (always?) temporarily rises to ca 1,4-1,5 bar, stays there for a fraction of a second and then returns to a steady 1,1-1,2 bar. When flooring it after this, the boost will never go above 1,1-1,2 bar.
Could this be my WGFV sticking on the first acceleration or what? Should I be concerned? Is the WGFV servicable?
I once got the "maximum boost pressure exceeded" fault code, but normally there are no fault codes stored.
The engine is a stock ABY.
