Guys,
I'm experiencing problems with my RS2 turbo leaking oil at idle
The unit has already been back to the turbo specialist and had a new set of seals, etc. However, it still seems to be having problems on my 3B motor.
As the engine has just been rebuilt I'm sure it isn't a problem with oil return pipes and breather hose condition. All the pipes have been checked or replaced. The exhaust has no cats, can this cause problems with low back pressure?
The only other suggestion has been the breather system. I replaced the pressure regulating valve some time ago and I'm now concerned that it may be fitted incorrectly. Can anyone with a 3B confirm the orientation of this little device, is it as shown in this pic?
Cheers,
Steve
The unit has already been back to the turbo specialist and had a new set of seals, etc. However, it still seems to be having problems on my 3B motor.As the engine has just been rebuilt I'm sure it isn't a problem with oil return pipes and breather hose condition. All the pipes have been checked or replaced. The exhaust has no cats, can this cause problems with low back pressure?
Cheers,
Steve
I've already been thinking of upgrading the turbo to get rid of the problem. I don't have any of the intake plumbing to go with it though and I know that takes a while to sort out. Good idea though
