I have the following problem with my '95 ABY: after I have been driving it, then shut off the engine for a while, it won't start. there is spark, there is fuel pressure, but it appears there is no signal (at least no voltage measured) on the controls to the injectors. after waiting some time, it will start. does anyone have any ideas what might be the cause of this problem? (no, I have not been able to VAG-COM it)
ABY sometimes not starting
Cam sensor. when it does its not starting trick, poor some water down the back of the cam pulley area.
It should then start, this test tells you its knackered!
Do a search for changing it,Rob..
87 UR 20v ABY
97 S6 Avant
1967 Ford Mustang,Eleanor,460ci v8Comment
fuel pump relay appears to be OK, since I do have fuel pressure when I try to start
do you mean an output test of the fuel pump?
sorry for the "blond" question (maybe my english isn't as good as I thought is should be): what do you mean with "the back of the cam pulley area"? cam pulley is the belt driving the cam I presume, so this would be at the front of the engine?
in another thread:
could be here as well?? hou do I check? measure electrical resistance? how many ohms should it be?Comment
The Perfectionist
Erm try 60-80 pounds from GSF when ordered as a Bosch part.
Infact the part only cost £30 from Bosch when ordered from a company that is trade.
Or you just change the sensor itself for £5 and drill out the pop rivet and replace it with a nut and bolt with locite.Comment
and now it does start when warm...
