oil temp reading
  • vonbeck
    • 2455
    oil temp reading
    moving on from ross`s cooling temp thread what should the oil temp be mine doesn`t seem to go much over the 70 degree mark is this right
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    do you mean in causual driving?if you have never changed the sender,it is often thought that over time they tend to show less than normal
    • vonbeck
      • 2455
      most types of driving usually, no i`ve never changed the sender though, have you a picci to point me in the general direction?
